- Jun 4, 2002
- 35,058
I spent some time trying to pull the cotter pin out. It was pretty rusted and did not was to be prior loose. The impact wrench sheared what was left of it off after I got done mangling it.
I am pretty happy about progress, however, the nut I put on to hit the stud through is still stuck. The stud just spins when I try and remove it. I am thinking that I will have to cut it off.
Take a jack and use that to "press" the taper back into the hole. This will hold it enough to get the nut off but will still be loose enough it will come out with a little light hammer tap. You may need to cut if you mushroomed the end of the threads too much.
