tie rods and drag link
m_m70
Pacifica, CA
have ben getting a little wobbly feel in my steering lately (by all means NOT the death wobble) but enough to be irritating to say the least. Crawled under there over the weekend and found I can rotate the tie rods somewhat easily by hand. I don't think this is normal and maybe they should be replaced?? Thinking about going with the heims %).
Any thoughts?
Timmy390
Conway, AR
I went back stock (moog) and added a WH adjustable drag link and track bar 2 years ago. No complaints and drives great.
Tim
ScanmanSteven
I have Heims and like them but, as has been mentioned before they are not street legal anywhere. If your state requires any inspection probably won't pass
Timmy390
Conway, AR
I went with this from WH, and the adjustable track bar. One order and all your steering is new.
http://www.wildhorses4x4.com/product/Tie_Rod_Drag_Link_3way_Adjustable_6675yr
I had planed on going that route and even ordered it. WH called and let me know it was on backorder (this was 2 years ago so I'm sure they have them in stock now). I chose not to wait and went back stock.
Again that was 2 years ago. Not bashing WH by any means. I chose not to wait.
Tim
m_m70
m_m70
Pacifica, CA
BR549
huntsville
Moog discontinued the right tie rod. ( the short one). I just bought a raybestos professional line tie rod end to finish out the moog set up.
SteveL
Huge chevy guy
Hawthorne ca
I went f-150 tro and really like it. With a little poking around on here you can do a ch^vy 1 ton set up that is similar for less $$
While they do rotate under normal circumstances (they're a ball-and-socket after all) I would have to say that anytime you can easily rotate the rods by hand, they're wearing, if not completely worn out already.
When they're new or still in good shape, you would have a very hard time rotating the assembly by hand.
But the proof of the pudding is to perform "the test" where you have a helper turn the steering wheel back and forth enough to make the tires move a little, while you carefully inspect all rods, links, ends, bushings and bearings. Even things like watching the steering box itself can sometimes let you see if you've got a cracked frame or not.
Still not a common thing on Broncos, but happens often enough to be aware of it.
Even with your new trackbar bushings you can still see the trackbar move side-to-side if your bolts are worn, or the holes in the bracket are wobbled out, or your lower stud has broken loose from the mount. Since it's just a big bolt tack-welded in place, if that weld cracks you will get some movement that can lead to wandering down the road.
All of it adds up. Heck, if you go out back while the helper is sawing the wheel back and forth, you might even find a loose u-bolt or bracket. The tires will push things that much.
Of course, the tires have to be fully on the ground for this test to work. Any weight taken off the system will lessen the effect and hide some worn parts.
Good luck. Well worth the five minutes of your time.
I recommend doing it any time your Bronco seems a little "loose" or twitchy. As often as needed.
roundhouse
Get a helper to saw the steering wheel back and forth and get a very bright flashlight at least 100 lumens
If you don't already have a sure fire or fenix or something comparable now is a good excuse to get one
I never thought I'd pay $80 for a flashlight but it's totally worth It
I keep it in my pocket with my spiderco knife and use it a dozen times a day it seems like
What size tires you running ?
If 33 or 35 and you don't do hardcore rock crawling then the stock setup should be fine. I got the one from WH with the adjustable track bar
After you Intall it. Find the best alignment shop around
If its an hour away. Fine. Go there
I did the toe in using the chalk and string
Seems like a simple job but it's totally worth the $80-100 to get a good shop to do it
You want a shop that can do work on big trucks etc
And in my experience the older system where they use the hanging gauges works better than the fancy new laser computer stuff
