Time to summerize the cooling system
jckkys
For those in northern climates it's recommended to winterize your vehicle. In hotter places like Az. even the weakest cooling system is OK in the winter. When it's over 100 or 110 or even 120 things get stressed. Does anyone have a check list of summerizing preparations for us desert rats?
blubuckaroo
Grease Monkey
Ridgefield WA
You shouldn't need to make changes for summer. It's pretty much the same as for winter as long as the fan and shroud are functional. Make sure the radiator is clean inside and out. A 50% mix of coolant and a good pressure cap will raise the boiling point. If you want to do some summer maintenance, hoses and belts seem to be the first trouble spots when it gets hot. One item that has always made a difference for me is to have the idle speed correct. If it's idling too slow, there won't be enough air flow through the radiator. There was a time I would change the thermostat when the seasons changed but for the last ten years or so, the 195 degree thermostat has worked fine year round.
J
jckkys
The original 7 blade flex fan is hard to screw up and if I didn't have a shroud I couldn't drive in the summer. I've done a lot of reading and opinions on what the best temperature thermostat for hot weather would be. There's not much agreement on the classic car sights. I tried 175 and 185 last year with good results. This year I'm going to try a 195. Many on the sights say 195 brings on percolation. Do you have FI or a carb?
blubuckaroo
Grease Monkey
Ridgefield WA
I don't think carbs percolate more because of a little hotter thermostat. I think the exhaust heat riser port running under the carb is usuallly the culprit.
J
jckkys
The cross over certainly adds heat but they were around at least from the mid fifties and fuel percolation didn't become an issue till the '80s when emission systems covered the engines with so many wires, tubes, and hoses that you could barely see the engine, while they only hurt efficiency. Now it's worse with gasohol. When I lived in the arctic region, specifically Chicago, I tried blocking the cross over; big mistake. The car ran like crap until the engine warmed up. Being cognizant of my error, I won't do that again. A cooler than 195 thermostat has in fact greatly reduced the percolation. I went by the radiator shop this morning to see what they recommend for a summer thermostat. They told me to select a thermostat that allows the engine to run well. The radiator will work as well with any thermostat opening temperature. Their other advise, like blubuckeroo, was a 50/50 antifreeze to water ratio, a 13lb. pressurized radiator cap, a Royal Purple type additive, and a check of hose conditions.
My next stop is the best automotive machine shop in town to hear what they have to say about various thermostats and what if any the effect on engine efficiency and wear would be.
J
jckkys
The engine builder and long time machinists who work there, agreed that any thermostat that allows the engine to run well, is good. The premature wear I worried about isn't a problem. If fuel percolation occurs, I'll put an aluminum heat shield from an '85 HO Mustang, over the phenolic spacer. Now that over heating the engine isn't a problem I can work on building a cushion that will allow worry free trips to the mountain on those 105+ days when 9000ft. and 80 degrees looks pretty good. The long hot grade was iffy with my original radiator, that was very tired after 40 yrs.
SHX669
Not sure what you meant by " original 7 blade flex fan - hard to screw up"
but when I was having issues with overheating I found my factory 7 blade fan must have been worn out {lost it "pitch" or something} but at idle it wouldn't hold a 8"x11" paper towel against the grille. I replaced it with a fan that does and actually pulls the paper onto the grille - something to check if you live in those warm places.
SHX
J
jckkys
How the OE could wear out is hard imagine. I'd love to see a photo of your "worn out" fan. I was once told by some knuckle head that a fixed blade fan would fix my over heating problem. I picked one up and found no improvement in cooling. I did find the fixed fans are incredibly noisy. Close examination of my 40yr+ old OE fan produced no sign of cracks, bent blades,etc. An assertion that one of these fans is doing nothing strains credibility. Stating that the fan is hard to screw up seems clear.
SHX669
What I meant is that I don't know what you're referring to ; it's hard to mount the fan backwards ? hard to get too close or far from the radiator ? hard not to clear the fan belts and the radiator hoses at the same time or if you do all of the above it's hard to screw up? or a fan is a fan?
I'm not the sharpest crayon in the box so sometimes I need more specific info. that's also probably why you've confused me again. You mention original flex fan - I always thought all the OEM fans were fixed blade { but I've learned not to say anything definitive about EBs} then you mention your 40+ year old fan and also mention how noisy fixed blade fans are . - So i'll go study up a bit and see if I can find out what fans came OEM on these things.
And along the lines of "definitive" I didn't make a positive/definitive statement about my fan not moving much air - as in -the blades lost there pitch- I said " must of lost it's pitch - worn out or something " I assumed that would be interpreted as a theory or possibility - mistake on my part to assume anything.
SHX
Oh - my aftermarket flex fans are noisy also - except at idle.
J
jckkys
If the original fan (there's a nice picture on TBP) that was always a 7 blade flex type on all V8s is installed with the original spacer, radiator, and shroud, it can't be installed backwards and it won't hit anything. You'll notice Tom wants $125 because the OE fan works better than any I've seen or tried. They move tons of air and do it quietly. It's not surprising that an EB that's been used by several owners has inferior parts and missing parts. I bought 2 of them new, so I don't have to guess what's supposed to be there. On the other hand, I've seen a bunch that were a bazaar collection junk from Pep Boys with many missing parts.
Once a motor mount separated on my '77 allowing the engine to lift till the fan ate the top of the shroud but didn't hurt the fan. So as I said, it's hard to screw it up.
blubuckaroo
Grease Monkey
Ridgefield WA
Are you serious?
That exhaust crossover is right under the carb. How could you not consider it a source of carb heat? BTW, all the aftermarket heads I've had haven't had the port drilled out for cross-over heat. Maybe they know something about it?
