This has been a common question as of late. I know ford still installed the eccentric on some of the early EFI set ups but I am not sure when ford stopped using the eccentrics all together. What I do know is that the 94 302 I have has a thicker cam gear. I had to surface grind .080 from the eccentric for it to clear the back side of the timing cover. I ground .100 to give me a little extra clearence for the cam end play.
Then you have the cam dowel length to worry about if you have the early one piece eccentric because the dowel locates the eccentric and the later two piece eccentric has a bent tab that locates it.
There could be a difference in the timing covers themselves and not the cam gears. That was something I never thought to check but I could see the cam gear was clearly different in thickness.
Some one asked if you could just change the chain. If you had a steel cam and crank gear you could get away with it but the old style with the nylon cam gear, no way would it work. The cam gear is what fails and when it does as mentioned it looses teeth. A new chain does not replace teeth on the cam gear. These old pot metal nylon cam gears can almost be broken by hand, cheap.
