needabronco
OK this one is embarrasing to ask. I checked my ignition timing today, and I can't figure this out. I've got a slightly warmed up 302 with an MSD dizzy, and with the vacuum port plugged, the light is about 10 +/- degrees out or before the timing marks, and with the vacuum line hooked up it is exactly on 10 degrees? Am I missing something here???? It does run very well with only some slight carb adjustment issues. I did verify that when at #1 TDC the timing pointer is at TDC or 0 on the balancer. If I remember right the balancer is a Summit brand part # SUM-163289. Thanks in advance.
