Hello all, I have a 1977 that passes California smog with flying colors (or did 1 year ago). Now retesting, the smog tech said the timing is not at 8 advanced as it needs to be to pass smog.
It starts right up, runs smooth and has tons of power so I assume the timing is on, or very close. He disconnected the vacuum advance line (did not plug either dist or hose) and said the light was hitting to the right of 0 on the indicator.
Is it possible the harmonic balancer spun the outer ring?
