I'm tearing down a full-width, high pinion Dana 44. I'm down to the axle shafts and need some suggestions on the removal of the Universal Joints.
I removed the snap rings. On my first attempt, I successfully pressed the cap out one side and then turned the yolk 180 degrees and tried to press the other cap out of its side. It didn't want to go through straight. I backed it out and tried again. It still doesn't want to go through its bore straight. I believe that I can muscle it through crooked, but I'm worried about the bore.
To your collective knowledge, is there any risk of the cap shaving a groove in its yolk bore if it doesn't pass through straight?
Is this a real problem, or am I just being paranoid?
Thanks,
Scotty
Thanks,
Scotty
