Tire sizing on a stock suspension 1976 Bronco
1976RedBronco
Hi everyone,
Trying to order a set of tires/wheels for my 1976 stock suspension bronco with no body lift with cut fenders and rear quarters. I am considering these specs.
A 32 x 11.50 tire
on a 15in rim (8in wide)
with 3.63 in backspacing
Would I be able to fit this configuration on my Bronco?
Thanks,
Maybe...
Depends on how cut the fenders and quarters are.
I've run as large as a 33x12.50R15 on 15x10 rims (standard old school backspacing whatever that was) with zero lift.
.94 OR
Willamette Valley, OR
If you are purchasing both tires and wheels, it might be worth a couple minutes to compare what a similar 17" wheel combo would look like. I'm finding fewer and fewer tire options in the 15" range and as these things become more vintage that will likely get worse.
I was thinking more of the clearing the sheetmetal. But yes on looking at 17s. I had a '77 F250 that was running ~32" tire and I put some 17" wide oval slots on it. The wheels were properly proportioned to the overall package. Really only ½" larger than the stock wheels. In short, yes, 17" wheel with tires you are considering are a really good idea to look at.
