Bronco1294
- Dec 27, 2016
- 66
I'm installing a 5.5 inch Duff lift on my Uncut 75 this weekend. Looking for anyone with a similar setup for tire/wheel suggestion. Thank you!
I have a 3.5 inch lift right now with 285/70/17 tire. The wheel is a Black rock 17x8 with 4.50 in. Backspacing. Looks awesome and my tires clear in the rear! The tires clear in the front also, I'm just losing a little bit of my turning radius since im using the stock radius arms. Ill be installing 5.5 inch lift in a couple days. But as of now, the Bronco is totally drivable with the 3.5 inch lift. The picture has the 3.5 inch lift.
You need to post more pics of your bronco! You are being super stingy with only four posts since 2015. I like the rocker guards, always wondered how it would look on an uncut bronco with your lift. Please add more pics!
Same lift setup as the inquiry? Or a different height?
