Tires to run on an UNCUT with 5.5 duffs lift
Bronco1294
I'm installing a 5.5 inch Duff lift on my Uncut 75 this weekend. Looking for anyone with a similar setup for tire/wheel suggestion. Thank you!
duffymahoney
Lots of tire height options. Most people run either a 2.5 or 3.5" with a 1" body lift. Are your goals 34x10.5?
doghows72
You'll need a wheel about 7-8" wide to fit under the back. I would think a maximum of a 10-10.5" width is all you can get under the back without narrowing your axle. Height anywhere from tiny to 34-35 maybe even a 36 if they make them that narrow.
For backspace you'll need at least 4-5" to fit under the rear. Those are my best guesses.
jmangi62
Here ya go. 5.5 sl. 1" body lift,35" Toyos w/17x9 wheels,3.5bs.:cool:
ryan97
Richmond
BFG used to make a 33x9.50 MT. Not sure if they still do, but always thought that tire looked good on an uncut lifted.
Teal68
Inlet Beach
This looks pretty bad with 5.5" lift and 35/12.5/15's on factory steel wheels:
slongoria
I have a 3.5 inch lift right now with 285/70/17 tire. The wheel is a Black rock 17x8 with 4.50 in. Backspacing. Looks awesome and my tires clear in the rear! The tires clear in the front also, I'm just losing a little bit of my turning radius since im using the stock radius arms. Ill be installing 5.5 inch lift in a couple days. But as of now, the Bronco is totally drivable with the 3.5 inch lift. The picture has the 3.5 inch lift.
JSmall
With a 5.5" lift I would run the new 34x10.5x17 BFG all terrain with a 17x8.5 w/ 4.75" backspacing.
Crawdad
You need to post more pics of your bronco! You are being super stingy with only four posts since 2015. I like the rocker guards, always wondered how it would look on an uncut bronco with your lift. Please add more pics!
66broncoCT
Torrington, CT
Mine only has a 3.5" lift but 3" body so probably pretty close to what yours would end up like. Cut in the front but not in the rear. I have 33x12.5R15 on it. Not sure of the offset on the rims sorry. I just barely touch the rear fender lip when I flex it. Its on my list to fold it in but after taking it offroad a few times the lip has started to fold itself in.
hucklburry rev2
I have a 3.5" duffs lift uncut and run 34x9.5 swampers. I think I can get a 10.5 under there maybe, will try next time, cause these are pizza cutters for sure.
Tuloyuser
X2 yeah @Crawdad, more pics!
sprdv1
REBEL
lol, nice rigs...
duffymahoney
Gosh you are lucky, I couldn't clear the 285 without narrowing and causing all sorts of issues that I have been fixing. Mine clear great now, but I don't see my bronco doing it any other way.
slongoria
Do you have rear disc brakes? Maybe since I have drum brakes in the rear it gave me more room without having to make any modifications.
slongoria
3.5 in lift. Adding 5.5 inch lift tomorrow.
The wheel and tire combination clears the fender
Here I have a jack under axel and the tire tucks in nicely without any fender contact.
Same lift setup as the inquiry? Or a different height?
