Title Update Change 6 Jan 2025: 2025 is the Year I Get it on the Road?
F
fordguy
A/c is wired. Starter, etc is wiredup. waiting on a few small parts byt making progress.
F
fordguy
More progress on wiring, waiting on black bezels. 3 wires left on EFI, fuel pump, fuel gauge sender, tail lights and headlights left. Steering column is wired for quick connect plug. We will be mostly done next week on wiring. Missing a couple of small items for engine before I get it wired to fire up again. We will tidy up harness before put the dash I and also radio will get wired and installed. Seats go out for upholstery late next week.
Not much room left for that Premier Power Welder.
Is that what was showing in the previous picture of the glovebox with the old (but nice) fuse panel?
F
fordguy
Getting closer on wiring and dash
F
fordguy
Paul I am not tracking what you are asking, no premier welder though.
Sorry. Just checked it again and found that post I was referring to (#159 on page 8) was actually pictures posted up by member 904Bronco just before you added some pictures of your own. Thought it was an early picture of your dash!
Sorry for the mixup.
F
fordguy
Headed to upholster by way of the supply house to pick up material
F
fordguy
Small things this week, but still moving forward. I received the one wheel I ordered with 4.75 bs, worked out good, still has to be painted or powder coated satin black. The dipstick for trans is 50 bucks from speedway. I have issues with p/s pump but Lee power steering is helping with that. Waiting on a few brake parts. Lokar linkage worked great on my column.
F
fordguy
Buttoning the motor back up , decided to use both pcv ports and the coolant lines going to the intake. Also figured a way to tie the purge valve into vacuum. I had previously run the engine in the frame but used an intake with more ports taken out than this one. Also painted the intake cover.
F
fordguy
cleaning up the engine bay while waiting on USPS to deliver parts, they have been out for delivery for 3 days, smh.
F
fordguy
Got tired of waiting on USPS, we made our own brake lines. Brakes are plumbed, hydro boost Monday. Also going to test fit hood for clearance. Steering shaft is in also.
