...the dash mounted OEM tank selector is only for fuel indication which uses resistance in the tank sensor
Sort of. But it's the senders themselves that vary the resistance, while the dash mounted switch is simply passing varying amounts of electricity.
The switch does not have it's own resistance valve (other than basic resistances that are in any switch I suppose) but the voltage passing through the switch contacts changes with the position of the sending unit variable resistor.
So if your tank is full, almost 6v is passing through the switch constantly. Or whatever 5-6 volts is, reduced by the roughly 10ohms of the sender before it reaches ground.
I probably did not word that correctly, and someone like Viperwolf could put it correctly. But the point I was making was that the switch is simply passing voltage. Just like any switch on our old vehicles.
In the case of the solenoid valve, it's just 12v rather than a lower value.
I don't know how many amps the switches are rated for, and the motorized valves would use less current in the long run, but apparently plenty of people (and Ford?) figure it's capable of handling the valve too.
Same as later model Ford trucks with dual tanks. Different design switch with it's plastic rocker rather than a metal toggle, but is probably rated the same. Or more if they have to pass any current from a fuel pump too, like I think some of them might.
