Viperwolf - I had built this circuit (I think correctly) per the previous revision in the original thread, however the wipers would not park when flipping the switch off, they just stopped. Could this update fix that problem or do I have another problem? Bad relay maybe?
And sorry to hijack a little, but I have a second question. I wired in a toggle switch for the reverse lights. I borrowed power from wiper circuit, then spliced the toggle switch into the wire for the reverse lamps...as soon as I flip that toggle, the 20A fuse blows (wipers were not running at the same time, but I had run them and cut them off just before flipping the switch)...is this too much power? Do they need their own fuse?
This is about the last thing that needs to happen before I can pass inspection...
