Top Coil Spring Buckets
redfishtony
Thomasville GA
OK Guys, I'm looking for some opinions or experiences. I have the '76 full width D44HP ready to install. With this said I need to adjust the spring perchs and upper buckets to square the springs up. I have looked at the buckets (Duff's #5112) but think I can remove the stock buckets, fabricate some spacers and re-weld them back in place and have the same thing when I'm done. I'd like to know if anyone can provide any experiences with full width axles and any tips/tricks that will be handy. Or other things I need to know. Thanks as always. TW
I've heard of them being done with either spacers on the towers/buckets, or moving the radius arm mounting pads inward, or a combination of both.
Many have done the full-width swap here though, so you should get some good answers pretty quick.
My feeling is the spacing out of the tower is probably the easiest, but adds a lot of leverage to the frame rails. Moving the mounting locations inward is a pain, but in your '76's case the pads are just welded and not cast-in like the '78 and '79 are. So should actually not be technically difficult.
And a combination of both might work out the best. Especially since it allows for the most spring alignment options on a lifted Bronco.
Apogee
Tangent, OR
I'm moving my "C" wedges inward on my '76 F150 HPD44 swap since I intend to roll my pinion angle to exactly where I want it at the same time, not just wherever it ends up, so in that way I can kill two birds with one stone so to speak.
Moving the springs/shocks outward is probably better from a handling perspective, but my rig is getting 37's, so race car it is not.
redfishtony
redfishtony
Thomasville GA
Apogee, So your going to narrow the full size axle to original bronco width? This was my intentions to begin with but after researching it there's alot of other stuff to adjust. Narrowing will still require adjusting the lower spring perch, moving the wedges and grinding off and adjusting the C's, correct. Narrowing mine would really give me the end result I want so ???? Decisions suck.....Thanks, TW
Sounds like he's just moving the wedges but leaving the tubes full length. That correct Apogee?
Another thing to do while you're at all that cutting of old welds, is to cut the steering yokes off too. When you twist the pinion up with the wedges and whatever bushings you'll be using, you're still going negative with the caster and will have to compensate with the yokes to get the caster back.
Guessing you already knew that but it wasn't mentioned so thought I'd throw it into the mix.
Apogee
Tangent, OR
Sorry I wasn't clear, but Paul is correct. My intention is to run the HP D44 at it's full-width width of 65" WMS-WMS for better stability combined with my 3.5" suspension lift and 2" body lift, plus 37's. I will push the C-wedges in to factory EB width (give or take), roll the pinion to get front driveshaft angle where I want it, and then cut and rotate the knuckles to set my caster at 5-6 degrees with 2 degree C-bushings in my CAGE long arms.
I'm swapping over to the heavier duty F150 box with the reversed internals at the same time to better deal with the 37" tires and ram assist, but I'm assuming the track bar and steering linkage will all be custom at that point. I haven't decided on TRE versus SRE yet.
Tobin
rjlougee
Since you're using a '76 HP D44 it will also have the C-bushing wedges welded on vs. the '78/9 style where they are cast into the tubes.
Basically, they are only welded at the top/bottom and are pretty easy to cut/grind through the welds and relocate.
If you do decide to narrow the axle, it would only require you to move the passenger side wedges, the driver side will line up like stock. You want to cut 6" out of the passenger side tube. Just remember, if you measure 6" from the inside of the knuckle, that will correspond to where the knuckle needs to be when welded back on, NOT where to cut...
I am running full widths on one rig and just just some 2"x4" rectube and welded it on inboard of the radius arms/cap. Bolt the coil spring cups down through the tube.
HTH, Joe
