Top off, now what?
BrettKoenecke
I took the hard top off my 73 Ranger. Took the wipers off etc. Lots of bolts.
OMG lots of bolts.
I feel like making some changes to that situation. I want cleaner rails in the back. Have others filled some of the holes and not reused them?
In my climate I definitely want a hard top for 7-8 months of the year. I just don't think we need that much attachment where the top is concerned.
miikee73
Shadetree Guru
Aloha
I'm afraid if you eliminated any holes on the bed rails the thin metal the top is made of would not seal unless you maybe strengthened the top with some 1/8 x1" strap. The holes need to be spaced evenly,so eliminating them may be more work than it's worth.
Thebeas
Camden, SC
I vote no on filling the holes in. They put so many to make the seal. Like you said, in SD you'll have it on most of the year. Broncos are suppose to have holes and bolts all over them. Well, mine does at least. ;D
rguest3
I would also NOT fill any holes in the bed rails. Also, maybe not re-install the rear corner posts (if they were still there) when you put the top back on for easier install/removal in the future.
CopperRanger
I put some plastic, body push bolts in the holes just to fill them in when the top is off, looks pretty good acually.
CopperRanger
I'll post a picture when I get home. I also got a extra set of houndstooth trim panels and cut off the lip that folds up over the bolt holes.
CopperRanger
Here's a few pictures of the back, looks a lot better than with it all open.
T4x4R
i welded in nuts...keep the seal with half the hardware to keep up with plus my random nuts and bolts coffee is now smaller.
