Torquing new ball joints
amc78cj7
Ann Arbor, MI
Bought and installed new greasable Moog Ball joints today for our '77 D44. Now I'm trying to install the knuckle on the housing yoke and running into problems. First, there are two sets of instructions that came with the two ball joints that have different recommended torque.
Here are the instuctions I TRIED to follow
1) tighten lock nut on lower ball joint to 70 ft.lbs (Unfortunately the stud starts to spin as soon as the lock thread hits the stud so you can't torque it down). To keep it from spinning I drew the balljoints into the sleeves with a C-clamp on the knuckle).
2) Torque upper spanner sleeve to 70 ft lbs (I did this, but at least 50% of spanner sleeve is below the Yoke treads now).
3) Torque upper castle nut to 100 ft lbs (Done)
4) (and this is only in one set of instructions but not the other) Torque lower ball joint to 120 ft. lbs. (This cannot be accomplished because the lower ball joint is spinning again.
HELP!
It is easier if the axle is in the truck. Use a floor jack to lift the knuckle. This will press the stud into the hole hard enough to hold it while you torque the nut.
My book shows steps 1-3 but not #4.
amc78cj7
amc78cj7
Ann Arbor, MI
Well I have decided to remove this first knuckle and start over to ensure proper torquing. Of course the lower ball joint stud is now rotating as I try to turn the lock nut. There is a slot in the stud that I can try to hold with a flathead screwdriver, but that is proving challenging.
If I use an impact wrench to get the lock nut off will I damage the ball joint?
69BroncoDad
Rutland
I just did my D44 with disc conversion...as soon as the joint started to spin....a few taps with hammer and it seated nicely....as far as the threads on the top joint mine stick out the bottom on one side by 3-4 threads.
and I did mine like I have always done....tighten the bottom nut good and snug with a 3/4 ratchet....and turn the top inner until it the steering starts to get tight...back off a hair ...snug top nut...waiting for a rainy day to use the pretty snap on T wrench.
