Cutting with a hacksaw can get old pretty quick, but if you have an angle grinder you can make quick work of all 8 tips with a quick swipe of a cutoff wheel.
Are these u-bolts new and used in conjunction with some other new components? Depending on what you're doing, leaving some extra thread is excellent advice!
If you're already as thick as you're ever going to be, such as with a new 11-leaf pack and a tapered shim, then you can cut them down to within just a few threads of the nut.
But it does make things easier. Torquing with a wrench is more than just a matter of getting them gutentight. Depending on the size of the bolts a minimum torque is going to be in the 60+ lb range. Up to about 120lbs for the big 5/8" size!
Have fun!
