I need to pick up the rolling chassis shown below.
I have a bumper with tow bar that I can attach to the front frame rails. The bumper weighs 90 pounds.
I have a bone stock '67 Bronco with 289 and manual drum brakes. The previous long time owner added a bumper mounted hitch that he used to tow around a small utility trailer.
The springs on the rolling chassis are believed to be 2" lift springs which would put the chassis frame above the frame of the '67 (tow bar on the bumper would slope down to the ball on the '67 hitch).
If I install a known good used manual steering box and drag link on the rolling chassis, can it safely be towed 150 miles over mountain roads with the stock EB and bumper mounted hitch or am I asking for trouble?
I've flat towed EBs before with a friend's 3/4 ton diesel Dodge Ram and frame mounted hitch, but I no longer have access to that truck. Using the '67 would be the cheapest and easiest solution, but like any rational person, I'd rather spend more money to rent something in the interest of safety if this seems like a bad idea.
Many of you here on the board have a lot more towing experience than I do. Seeking knowledgeable input.
In addition to the photo of the rolling chassis I need to move, I've also included a photo of the bumper mounted hitch on the '67. The hitch is bolted to the frame using the two lower bumper mounting points and three more bolts directly to the bumper in between the lower frame mounting points.
