- May 28, 2013
- 1,982
Planning on installing the WH track bar riser and wanted you'alls thoughts on my plan.
Option 1:
One of the reasons for doing this is my track bar drop bracket hits my heavy duty coil cups under full compression. I plan to raise the hole on the drop bracket and cut off the excess. See pic.
On the axle side I plan to use the first hole which will raise the track bar 1.5" on both sides. The problem is the track bar riser hit the heavy duty coil cup which will require removing a section of the riser bracket. I don't think this will weaken the bracket. Thoughts? Its pretty stout.
Later or maybe now, I plan on tie rod over. Flipping the tie rods will raise them 3" then go with a stock pitman arm should put the track bar and drag link back paralel, but 1.5" further from one another then they are now.
My tie rod ends are very close to my wheel rim, about 3/16". Will putting the tire rod on top bring them closer to the rim?
* The issue with this option is it doesn't flatten our my track bar and drag link!
Option 2:
Do all of the above but install the track bar on the top hole of the raiser bracket for a total of 3"
** The issue with option two is it may put the riser bracket in contact with the frame at full compression, but maybe the bump stop will hand that.
And the biggest issue, this will take my track bar and drag link out of parralel since I haven't found a 1.5" drop pitman arm.
Option 3:
Put the track bar in the original hole in the drop bracket and just do some grinding on the coil cup where it comes in contact.
Thanks in advance for you input!
Option 1:
Option 2:
Option 3:
