- Nov 3, 2003
- 49,244
To your question about whether the WH steering linkage will work with the full-size Pitman Arm. The answer is, not without a little assistance.
The tapered hole for the rod end is much larger on the full size than the early bronco. Especially the 76/77 bronco, which yours is meant to work with.
So you’ll need one of the tapered shims to allow the smaller rod end to fit tightly in the larger Pitman Arm. Not sure of all the exact sizes and if ours will work or if you have to go with someone else’s.
Somebody at the office can give it a try though.
It’s been so long since I’ve done it I don’t remember which ones work or if you’ll have to swap the 76/77 draglink for the earlier 66/75.
But it can probably work either way.
