tracking devices?
jckkys
I've heard good things about lojack, but I have no personal experience.
Remos69
SW Florida
My jack russell is great at tracking wounded deer and pigs, not sure how she would do with a bronco or wounded bronco driver!
1970 Palmer
LoJack is based on a FM radio signal. It only works in a metro area where you have the receivers in police cars. It will not get your Bronco back if the thief takes the vehicle to a remote area.
I was certified to install LoJack's on new motorcycles. LoJack would only allow installations on street motorcycles, no off road motorcycles, no ATV's, no UTV's etc.
I think some kind of a GPS or cell phone system would give better results.
John
Green_Bastard
I’m using an alarm system with cellular connection and GPS tracking. Seems to be a decent option
navi
Let's say you track your misappropriated bronco to some local or non-local chop shop. Call the police in that area and hope they will go get it?
Here, I'm not sure the local pd would make it much of a priority.
jckkys
Tucson has 9 times the national per capita auto theft rate. A huge percentage go to Mexico where US victims have little legal recourse. It's hard to get your property back off the reservations too. To top it off, large swaths of the state have no cell service. I revert to my old Chicago car theft avoidance regimen, where I only spent time in buildings like restaurants where I could keep an eye on my vehicle. I also plan on getting the Club.
nvrstuk
PNW
SW has such vast expanses of non-metropolitan areas w/o cell signals using a phone would be worthless. I always worry some when we go hiking and leave the Bronco at the mouth of the canyon... and another thing... if that cell signal is from a company like US Cell or Verizon you will have much great luck receiving a signal in rural areas than the "metro-carriers" as we like to call them as they cater to the large population centers and freeways but not where us farmers live... :) T Mobile and Sprint are worthless in most rural areas...
It's like anything... insure it and don't live being paranoid. I've thought of a quick disconnect strg wheel. Keeps the locals with a pickup and a chain from being able to tow it away... at least if they try steering it with vise-grips and can't turn it worth a darn because of the hyd ram then when the Bronco swerves off the road it will take the truck with it!! :
Truck fleets use a small transmitter that relies on cell service. Very small only a few bucks/month...
KingR
I use Americaloc and have been happy with it. You can pay by the month as needed. Set up a "Geofence" to be alerted if the truck moves from within a specified location. There is a movement notification as well- but it's pretty sensitive and I've often found it alerted to movement with just a stiff wind. https://us.americaloc.com
I've heard of a LoJack on a tractor working before as well. A police car with the receiver was driving around and got a hit. Circled the block and narrowed it down.
No Hay
Ha! Yep, the folks we bought our house from, said "you're ok here, but DON"T leave the Bronco out overnight anywhere else, or it will be in Mexico in an hour."
Whenever we come out of the store or restaurant, I say, cool, it's still here ;D
I do install the Club
jckkys
I've worked on construction sights where the heavy equipment and tool boxes were all chained together. It worked in the '70s. Now with cordless cut off wheels it may take that plus something more. Of course as a firefighter we had gas powered K-12s that would make short work of even the biggest chains.
70 sport WA
I’m surprise nobody said this yet. If you have dual tanks, move the thanks selector switch to the middle position; someone might get a half block run out of gas. Or move the transfer case to the neutral position. Hide a cut off switch to the coil.
56f100bbw
Tucson / lakeside AZ
I have a hidden switch that goes to a 12 volt Solenoid fuel cut off so before I stop the vehicle I turn it off so if they get it going or not going far I only have a single gas tank on bronco.Club idea is good and park it where a flat bed wrecker can’t get to it
nvrstuk
PNW
How many thieves start it up and drive away...?
Drag it up on a roll back and gone in less than a minute...even with all 4 wheels dragging. Guy here on CB years ago talked about riding with a repo friend of his for a day... pretty amazing how quickly they can slide a rig on the deck and nobody gives them a second look. He'd spray the bleach on the ground in front of the tires so it would slide quietly and easily. All you need is a vinyl graphic on the side to look legal.
Pull up with a rope and a truck in front and it's gone in 30 seconds.
We just hope to delay them enough till we show up which usually isn't soon enough...
