I have been looking into putting a traction bar in recently and have run into a problem with trying to find a place to install it. The issue is that I have a Dana 60 rear end that was narrowed to the original axle width. The housing on the D60 is about 19.5" wide, and the inside dimension on the frame is like 24.25", so that only leaves ~5" extra room on the axle tube to locate the mounts. The housing is not perfectly centered, it is biased slightly to the passenger side and leaves most of the room on the drivers side. And the mount width is like 3.125" when installed... hardly enough room to get a bead in on the tube next to the housing.
So, my question is - do I try and find a way to install it on the passenger side by welding into the cast housing, or do I just put it on the drivers side with the little room that is available? I have read that the bar should be on the pass side to help with the compression that happens on that side due to toque - how important is that? I have a fair amount of torque, but will it make a difference?
I prefer the traditional route, but something like the torque tamer is also an issue because of the cast housing. I am not sure the housing is the best to weld into anyways for something like this without adding major support.
Of course its going to mean I have to change the routing of my exhaust since there is not much room in there for that either...
Just looking for advice and ideas. Thanks!
Eric
Eric
