Tranny crossmember
Baja71
What is the difference between a 3spd manual and C4 auto crossmember? Are they the same?
The 3 speed gets covered in 90 weight gear oil when the transmission leaks and the C4 gets covered in type F when the transmission leaks.
There is no difference.
Baja71
Baja71
:) I guess that means mine with get covered in both, eventually! ;D
Thanks!
tw
Incognito
Key West, Florida
Crossmember
How about the AOD is there crossmember modification required?
I swapped a built up c-4 in my 69 for the 3 spd I will be swapping for an auto but want the AOD this time.
bax
Old Member
yes new crossmember for an AOD
