bronconate
Pulled out 170 and 3 speed today, putting in v8 3 speed, have three questions. Thanks for some clarity.
1. This bracket is on my v8 tranny, it was formerly hurst floor shift but is going back to column shift. I dont have a bracket that looks like this on my I6 tranny that I just pulled out, so do I need it or can I just take it off and replace it with the linkage from the I6 tranny?
V8 Bracket
I6 Linkage
2. Will my v8 transmission sit in the same spot as the 6 cylinders or will I need to move the crossmembers support brackets to another place along the frame?
3. Here is my big one. Im assuming the rods that run from the steering column to the side of the transmission gear selectors will be ok to use on the v8 tranny. What Im not sure about are the actual gear level selectors, being that my I6 tranny and my v8 tranny have two different ones (im not sure what the v8 tranny was pulled from) but it used to have a hurst floor shift so Im thinking that i pull the 6's off and put them on the v8 tranny being that Im going to continue to use the column shift and not the hurst. Here are pictures of what Im talking about
The V8's fomerly hurst floor shift gear selector levers on transmission
The I6 column shift gear selector levers
V8 Bracket
I6 Linkage
