Tranny temp sender ?
BUCKETOBOLTS
Salisbury, NC
I've always put them in the pan. I have seen them in a block that fits in the line returning from the cooler also. But the pan is usually easier and out of the way.
1975stroppebaja
I put one on my '84 Ranger and I installed it inline with the cooler line that comes from the transmission and goes into the radiator. I figure if I'm looking at the non-cooled fluid then I'm seeing the worst-case temp.
Good luck!
74bob
Broomfield,CO
I put it in my remote filter housing. I heard that the line out of the tranny runs hotter than the pan temp, which is where everyone recommends it to be, but I've run a couple on the line out with no problems.
Paco
Pueblo, CO
On my C4, which I recently had rebuilt, there is a plug on the drivers side that will work. At least that's what the shop that rebuilt my C4 said. I did remove the plug and inserted the sending unit in this hole, but I just didn't feel comfortable leaving it since I couldn't really see all the way into the hole. So I'll probably end up putting it in the pan, although putting it in the line out sounds like the best place to me.
72_EB
66to77
Yes, the Autometer electric sender will fit in here, BUT I DON'T RECOMMEND IT! I had a problem with mine (and so did another member on here) with the trans acting funny (shifting) after this. Others have said they have not experienced anything, but why risk it?
If you're only running one, I'd say put it in the pan and don't overly worry about it. Mine is pan mounted.
