There’s two motions to this system. 1. Moving the seat in and out of the vehicle which the wiper motors driven gear /rack system will do and 2. Up /down which the hydraulic system will do because it will require some force once there’s a load on the seat (me) lol !What is the connection between the hydraulic system and the spur gear on the wipers? Kinda got my curiosity up.
Randy
Thanks once I get the inner slide together I’m going to load test it to see if there’s any flex. I’m hoping these 500lb drawer slides are substantial enough to hold my weight. I’m thinking that since the slides are boxed in it will prevent any twistThis is some great engineering! Looking forward to seeing it operate.
I trust that you’re gonna static load test before you hop on and try it out. Learned the hard way with a climbing deer stand that my weight was more than the attached parts would stand. LolThanks once I get the inner slide together I’m going to load test it to see if there’s any flex. I’m hoping these 500lb drawer slides are substantial enough to hold my weight. I’m thinking that since the slides are boxed in it will prevent any twist
Hi speeder I posted up specs earlier in the post, yeah you could assemble the parts in reverse fashion but once they’re welded together then that’s it. It would actually require less work than the drivers side because you won’t have to drop the floor pan like you will with the driver side.Is there any chance you could/would post a set of drawings (I would pay) and specs of this item??? I am certainly interested in seeing the final design in action. As an aside, would mirror image work for the passenger side??
Randy
I’m hoping so!!Looking good! I’m betting that the “weight test” is gonna go as smoothly as video shows…at least I’d bet on it.
Ra
