Transmission cooling
Dannyboy71
I am thinking of painting my auto trans, would this cause it to retain the heat more? Also I will be running a plate cooler but don't like the idea of the fan running all the time. Has anyone ever used a tube and fin type and then the plate. My thinking is maybe while on the road the tube and fin would keep it cool enough to not activate the plate cooler. The plate then would come on at idle situations? Would that work?
blubuckaroo
Grease Monkey
Ridgefield WA
Coating will slow the heat transfer to the air a little but I've even seen remanufactured transmissions that have been painted. I don't think it's that big a deal.
For your cooler, why not just use the cooler in the radiator tank? Heat transfers to liquid a lot better. It would take a huge air cooler to replace it.
D
Dannyboy71
It is a manual trans right now. I am pretty sure there is no cooler for the auto, although I should check it is an Be-Cool and never looked at it closely.
74strokerbronco
Monmouth, OR
you can run two coolers inline/ in series with each other no problem as long as you use non restrictive fittings and lines and no sharp bends in the lines, no hard 90* turns etc. you really cant over cool a c4, even if you have the pump and cooler case passage mods done to your c4 you still can't overcool them they just don't flow that much volume thru the coolers. I run a 26k rated cooler on my eb and we got a explorer we used to use to pull a tandom axle trailer with 5 quads on it 70 miles to the dunes over the coast range mountains and the trans used to overheat and puke all the fluid even on cool days , last year we did a trip in the summer on a 90* day , 5 quads and gear/fuel for a week for 5 people with the same explorer, only difference was this time I installed 2 yes TWO 18k rated tube type coolers in series with each other and eliminated the radiator cooler. why would you want to add heat to the radiator and why would you want to heat you trans fluid to 190 or 200 degrees coolant temps. the explorer made the trip there and back with zero issues !!
