you can run two coolers inline/ in series with each other no problem as long as you use non restrictive fittings and lines and no sharp bends in the lines, no hard 90* turns etc. you really cant over cool a c4, even if you have the pump and cooler case passage mods done to your c4 you still can't overcool them they just don't flow that much volume thru the coolers. I run a 26k rated cooler on my eb and we got a explorer we used to use to pull a tandom axle trailer with 5 quads on it 70 miles to the dunes over the coast range mountains and the trans used to overheat and puke all the fluid even on cool days , last year we did a trip in the summer on a 90* day , 5 quads and gear/fuel for a week for 5 people with the same explorer, only difference was this time I installed 2 yes TWO 18k rated tube type coolers in series with each other and eliminated the radiator cooler. why would you want to add heat to the radiator and why would you want to heat you trans fluid to 190 or 200 degrees coolant temps. the explorer made the trip there and back with zero issues !!
