Transmission Guru ?
DEEPWOODS
Anyone know if the 4R70W V8 -2 bolt starter main cases are the same from 96 To 2000 ? 2nd question can I use the internals from a 2001 3 bolt starter main case in a 97 main case ?
Yes, yes.
There are a few differences, but nothing that is a show stopper. I recall some things like a couple of port filters. Valve body tweaks. Double check the OSS ring, this is about the time they changed the number of teeth. If running a stand alone controller, simple change a setting.
I once put '00(?) guts into a '95 AODE case.
Sounds like you have both. Best I can advise, compare them side by side as you take them apart/put them together.
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
Internals from the mod motor case should swap into the 97 case. You’ll need to use the 97 valve body and electronics.
The case connector uses the same bore. I've swapped that part before. Late guts in an early case. I have even installed a digital range sensor in place of an analog one. The stuff I remember for 20+ years ago.
