fastride
Hello, I am really needing somebody that is good with C4 transmissions. I have just changed the filter and fluid in my 76 and it is slipping when I get on it but if I just start off normal, it doesn't slip. The filter that was in it was the one that has the cut out toward the pan and the new one has the hole in it for a pick up tube. Also, I need to know if the adapter that is cupped on top that sits in the spring that is held up by the filter is supposed to have a ball or something that goes between the adapter and the transmission. Can somebody help me out with this.
