Transmission vacuum line question
GloNDark
I've been figthing some strange transmission issues with my C4. Weird intermitant no reverse, strange 3rd gear shifting/non shifting.
I changed out my reverse servo piston, and put another new vacuum modulator in there. But I was realizing that my vacuum line from the manifold is ALL RUBBER, could this be part of my problem? I know stock they were steel with about 2" or less of rubber.
Obviously seeing as mine was originally a manual, I don't have the stock steel one so, can a steel brakeline be used instead?
opinions?
Thanks!
Chris
garberz
Bronco Influencer
Conejo Valley, Ca.
Yes, It needs to be steel. Over time, that length of rubber will not support itself, especially with all the heat. I used some 1/4" steel line from part of my vapor emissions system on mine.
