Transmission vent spewing
badbronco
south carolina...
My 77 Bronco has always spit out transmission fluid in the tansmission to transfer case adapter. It comes from the little vent right next to the shift lever for the transfer case. I know that they are supposed to vent. I blew the old c-4 and installed a remanufactured one. It still does the same thing. I am about to weld it shut. I also know that the tansmission and the transfer have their seperate vents so if I do weld it I don't think it will hurt.
72Sport
Pressure build up is going to go somewhere. Probably blow a seal. Maybe a dipstick problem? Too much fluid. Just guessing. Find someone with a c4 Bronco and borrow their dipstick to check your fluid level.
B
badbronco
south carolina...
I fixed it.....
We'll I think I fixed my spewing problem. I used drip check sealer to fill my vent tube and spewed like hell from somewhere else and I had to unplug the hole on the side of the road. Now it won't leak a drop.Hmm...darn strange...
