I'll second staying away from the first generation of the heads, unless you want to be rebuilding them ~20k or so. Try to get the serial # of the heads and give Trick flow a call and inquire about them . The current heads being sold are their third generation (they went through 2 generations when Trick Flow was a sole entity, they are now owned by Summit racing's parent company and are on their third generation design). If you do get them, buy an adjustable push rod and use the instructions on the Trick Flow web site to get the proper push rod length - the rocker geometry is very critial on these heads! For the $$ they still offer good bang for the buck - however I would prefer the new generation Edlebrock, Cainfeld, or AFR heads over them if I was buying new. Since your getting a deal on used ones, just make sure they are in good shape as getting them properly rebuilt can be ~$1k depending on what needs to be done.
