Trick Flow twisted wedge heads ?
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
Anyone use them ? I found a local guy with a nice pair but I'm unsure if they would work with my pistons and a .500 lift cam. I would just call Trick Flow and ask but it is 1:30 am on a saturday morning. Probably nobody there :)
j.r.nice
I got 'em.......Keith Craft put my short block together. He had to have special pistons made (JE I believe). It was because of the heads. Some consideration for the blower. I cant find the specs on the cam but I dont think it's real radical.,
Probably more relevant, I also had the same heads on a 302 with forged pistons, flycut like the originals. The cam was a Comp Cams 268 with .500 lift. No problems with it, even floated the valves a couple times.
I think I would run the "clay test" just to make sure nothing is going to hit.
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
I would do the clay test IF I owned the heads already. If they wont work as is, I'm not buying them. I don't want to fly cut junk pistons just so I can ride around. I did figure that the heads would be nice to have for future engine. I was going to call and order heads tomorrow and these came up. If they will work , I'll buy them. If not i'll just buy something NEW and have to wait the extra days for shipping. I want to ride NOW !
broncnaz
I use them and really like them the .500 lift may not be a problem as long as duration is limited to 290 and under. above 290 dur. will require flycut pistons. as always check all your clearances. Also these heads are not exactly bolt on and run you will also need longer pushrods since the decks on the head are thicker than stock on my 73 with hydralic cam the pushrods worked out to be 7.250. I would definitely call TFS they will know exactly what you need for your combo.
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
broncnaz - The trick flow web site tells quite a bit. They say to use a 7.300 pushrod and list other parts that may be needed. I was going to order a pair of Performer RPM heads but these are local.
mustangmarty
I'm using them and like them. However, I had to grind out the inside of the roller rockers because the geometry of the twisted wedge heads kept snapping my rocker studs.
broncnaz
Thats cool. way back when I bought mine there was no web site I'll have to go check it out
iwlbcnu
How old are they? Trick Flow has a tendancy to wear out vavle guides pretty quickly if the rocker geometry isn't exactly right. And they use a different set-up than a stock engine, so you will be buying new push rods and rockers. If they are the first versions, stay away.
The design of them allows for the bigger intaqke valve to still clear stock pistons.
I just bought a 347 w/ 900 miles that had Trick Flow heads and had already dropped a valve and took out the block.
Personally I would never own a set, but they are the most popular out there.
bsaunder
I'll second staying away from the first generation of the heads, unless you want to be rebuilding them ~20k or so. Try to get the serial # of the heads and give Trick flow a call and inquire about them . The current heads being sold are their third generation (they went through 2 generations when Trick Flow was a sole entity, they are now owned by Summit racing's parent company and are on their third generation design). If you do get them, buy an adjustable push rod and use the instructions on the Trick Flow web site to get the proper push rod length - the rocker geometry is very critial on these heads! For the $$ they still offer good bang for the buck - however I would prefer the new generation Edlebrock, Cainfeld, or AFR heads over them if I was buying new. Since your getting a deal on used ones, just make sure they are in good shape as getting them properly rebuilt can be ~$1k depending on what needs to be done.
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
NO Trick Flow heads for me. I bought some Edelbrock Performer RPM heads brand new from Summit. My choice was the world products Windsor Jr LITES but I didn't want to pay more that $100 each for them over every other head on the market. The lites cost more than a Victor Jr head. I think I'll be okay for now and the future with the Performer RPM heads. They were very reasonable $1080 a pair complete.
BUCKETOBOLTS
Salisbury, NC
I prefer the Edelbrock heads over the Twisted any day. Much better fit and finish. All the threaded holes have steel threaded helicoils. Unless your going to drag race your rig I don't think you could tell the difference by the seat of your pants.
iwlbcnu
I have the Performer heads on my stang and the only trouble i have had in 6 yrs and 40k of hard running is that the versions I have didn't come w/ hardened spring cups or shims and I ended up pulling most of them out of the oil pan, but that was a few yrs ago and they fixed the problem since. It was a big issue on Corral then and Edelbrock gave most new cups, but you ate the labor. That was in 01.
I have been running trick flows for about 22k miles, got them used back in '99. They are the ones with the reciever groove.
Biggest problem has been head gaskets. They never blow out or fail completely, just start leaking compression into the cooling system. The first time I blame on reusing stock head bolts (I was poor back then). Second time was when the reciever groove started loosing it's edge and the fire ring started to roll into the combustion chamber. Might have something to do with 200PSI cranking compression too.
The heads are now milled without the groove and we will be trying a set of Cometic gaskets.
No valve problems and the trans is set to shift at 5800 RPM
j.r.nice
Just for my info, what happens when it does this, and how do you know?
iwlbcnu
Sounds like you were running the Fel-pro 1011 series head gaskets. They are prone for this. Fel-pro told me they were a race gasket and could not stand up to the heat cycles and extended use of a street engine. They recommended the 3933 FT-1 gaskets fro street use. I have never had a problem with these, but blew a set of the 1011's after 10k on a 258 rwhp engine before building the new combo.
When they died on me, the overflow bottle would fill up as the compression forced the water out of the radiator. That was my clue. Another is a brown greasy, muddy froth on the bottom of the radiator cap.
Was more of an annoyance then anything else. I would still drive the truck for months afterward, sometimes even pulling trailers and fighting Phoenix rushhour traffic in the summer. It does tend to run warmer when the water is in the overflow bottle instead of the radiator too. Never stranded me and I believe that I could still drive cross country if need by without complete failure.
I think that they are the 1011's, it is the standard gaskets that come in the trickflow O-ringed gasket set. I have a pair of brand new ones that I need to sell.
broncnaz
Had the same type of problem with with my headgaskets cant remember the fel pro p/n but it was the one with the copper cylinder ring that was one of the suggested gaskets they didnt last long started leaking water into the #1 cylinder swapped them head gaskets for the standard pre flattened wire ring and 75,000 miles later no problems
