Turnsignal doesn't turn off
JohnT
West Virginia
Turnsignal doesn't off after making a turn . Can anybody help me . I took steering wheel off everything looks to be in place . Does anybody have any insite on this problem.
SteveL
Huge chevy guy
Hawthorne ca
There's a little plastic tap in the column behind the wheel that clicks em off when the wheel returns. Take another look in there and see ir it broke off.
70_Steve
Old Guy
Stock wheel or aftermarket. Some of the aftermarket wheels use a roll pin to hit the arms on the turn signal switch. And those roll pins have been known to fall out.
J
JohnT
West Virginia
It's after market streeing , It was on the Bronco when I got it. I seen the plastic tabs on both side of the control , but there nothing on the shaft . Does anybody have picture of what I'm looking for ?
70_Steve
Old Guy
I put a Grant wheel on mine, but used the stock c-clip to turn off the signals. The c-clip is a cylindrical piece of spring steel with a "bump" on one side. It goes over the steering shaft with the "bump" opposite the turn signal switch. The "bump" is what hits the arms on the switch to turn them off. I can't seem to find a good pic of the Grant adapter with the roll pins showing.
J
JohnT
West Virginia
Well from what I can see in this picture compared to what I have I think the C clip is M I A .Does that C clip hold the shaft up in the housing ? I hope I can find one . Any thoughts to who would have one maybe JBG ?
70_Steve
Old Guy
I did some searching and found the Grant instructions for the Bronco adapter. The instuctions have changed a little since I put mine on 12 years ago, because these instructions refer to reusing the c-clip. But there are additional instructions for using the roll pins.
http://www.grantproducts.com/files/instructions/97503-00-01.pdf
http://www.grantproducts.com/files/instructions/97513-00-01.pdf
And there is an even better picture than the LMC pictures of what that "c-clip" looks like. It's just a piece of spring steel that clamps around the steering shaft.
J
JohnT
West Virginia
Thanks guys that make a lot sense now . If I can get a hold of Grant maybe I buy that piece from them , if not I'll call LMC . Thanks again , Boy without knowing what your looking for it really hard to find it . Thanks again !!
