I've been dickin with this transfer case all week...and it's fighting me the whole way thru. I managed to get the rear shift rail set screw out. It took A LOT of heating and pounding to get it free. I think what finally made it release was the whack on a punch that was down in the bottom of it. I put a small diameter punch in the bottom of the allen socket and wacked it with a 5lb. sledge.
So, with the rear out, I then moved to the front shift rail. Of course the front set screw is just as tight and not budging. Heated it many times, tried every combo of allen wrench, socket, etc. I was trying to get this one out without removing the front gear stack...but that idea has now been abandoned. With the front gear stack in there, it gives very limited room to get at the set screw.
Now trying to get the front gear stack out of the case, and that is presenting it's own set of road blocks. I'm using the wt4x4.... link that I posted above as a guideline. Where I'm stuck is trying to pry the front bearing forward off the shaft to get at the snap ring that holds the front shaft together. Any tricks to get that bearing off the shaft? Thanks in advance!
