Twin stick rant
NC-Fordguy
Bethel/Greenville NC
Guys...
Just installed a new dana20(well a used one, but new to me) and I also twin sticked it. I bought the kit from one of the vendors who advertise here and I am a bit disappointed. IMO the instructions were poorly written.
After getting everything installed the test drive was a disaster, After a couple of shifts, getting the feel of it, One of the sticks broke right off. Very poor weld job. Of course this happened when I shifted into neutral. So here I am 5 miles out with a truck I can't move. Some fiddling with a needle nose vice grip(Fortunately I did cut a bigger hole) I got the shift rail to pop back into high.
Back to the shop. Mulled over what I was going to do, then said F*&$ it and cut a bigger hole so I could weld it back together. I was not going to pull the t-case out again.
For the 150 dollars spent I expected better.
Ed
77BroncoWag
got mine from jb fab for 85 bucks off ebay and it has worked perfectly so far
GrantMurray
Austin, Texas
One of the best mods I've done...sorry for your trouble. Should have come factory like this, but I guess the average joe would have trouble remembering the protocol for the shifting patterns...
pikapp691
On the JBFAB do you have to modify the shift rails? Is there a company where they do not have to be modified?
blazinchuck
Sorry to hear that Ed! I got mine from Tom's...but it was a J-shift-a little different than yours. Which stick broke? the front or rear? Did ya conntact the vender yet...maybe they will send a new one or make it up to ya.Chuck
DU 001
Houston, Texas
Twin Stick Rant
Sorry you had such a horrible experience.
JBFab user here and I have had no problems at all. Moreover, Jon and his staff are the very best to do business with and their products are superior quality.
FWIW, this site provided significant help on selection and installation when I decided to twin mine; specifically, how to cut the shift rails.
There's a lot of good folks that contribute to this site and most are always willing to help wherever possible.
Hope you have better luck in the future.
Regards,
DU 001
NC-Fordguy
NC-Fordguy
Guys...
That jbfab stick set-up looks pretty slick...Is that machined or welded together??? Might try that if I have another issue.
Chuck...nah didn't contact the vendor...just welded it back together as I didn't feel like waiting two weeks to get it resolved. I guess who ever made the stick I have for this particular vendor had a 'tard with a stigmatism as a welder...total crystalized weld. I think one of my dogs could have done a better job welding%) %)
Ed
BUCKETOBOLTS
Salisbury, NC
Ed, do you have a T or J shift transfercase? I built my twinstick a while back. Mine looks really over kill, but I'm not afraid to put my feet on the dash and pull will all I got. I put the shifter in then 6 months later I removed the "pills" in the case when I rebuilt the drive train. It shifts fairly easy now.
Skiddy
No any and all of them you will have to modify your shift rails. But it's real easy to do on a J-shift.
vertex
Oregon City
Has anyone tried this twin stick setup?
I like the idea of the greasable bushing. The ebay add states that is is stainless steel but I am not sure why the epoxy paint on the lower portion. If it was all stainless why waste the time.
Next summer I am planning to do my floor boards and convert to twin stick at the same time so I am just doing some research. I will more than likely buy from jb fab.
blazinchuck
It does look like a nice piece, however I would check out all of the feed backa and ask them a few questions that concerned you. It does say 100% money back. Maybe somebody else will chime in on its quality for ya,Chuck
