Viperwolf1 has the correct pattern defined.
What I do from 4lo to 4hi is to put the front range (left stick) in Neutral (can be done while in motion and in drive or neutral on the tranny), then put the tranny in neutral and shift the rear from lo to neutral to high. I do this while moving so any bind can be released, just don't force it. You don't want to be going too fast, but I have found that all of this works better in motion than at a dead stop.
In my experience, sitting still in Park requires the most effort and there is no way to release any existing driveline bind. You have to put too much pressure (in my opinion) on the shifters. Sometimes it requires shifting the tranny into and out of park, neutral, and Drive while pulling on the transfer case shifters.
