Twin Sticks with factory bench seat
Timmy390
Conway, AR
Thought crossed my mind last night.....
Anyone running twin sticks (J shift) with a factory bench seat? I'm about to drop the hammer on past for my 5 speed swap and don't think I have ever heard of any issues with the twins and a bench but don't recall anyone saying they run that combo either.
Tim
okie4570
NW OK
I've not seen that either, I can't imagine there being a clearance issue though.
okie4570
NW OK
Not a J stick but there's a ton of room there.
Crush
Greenbottom, WV
if you get the twins that have straight shifters on them then you will probably not have an issue. but if you use Duffs twin stick the shifters are bent towards the rear and they come back to just touching the inside front edge of my driver seat. that is the front stick does. you can measure. the m5od with adapter is 9" longer. so you can measure back 9" and see for yourself.
Found a pic for ya
attachment.php
Timmy390
Timmy390
Conway, AR
Worried about the M5ODR2 length and where it puts the twins.
I guess I could bend the shifters if need be.......Not giving up my bench. Love it....
Tim
Timmy390
Timmy390
Conway, AR
Plan to go with JB Fab twins. This site has a listing for ZF/M5OD J shift twins. Not sure of the difference but it states "works with AA clocking rig"
Tim
Timmy390
Timmy390
Conway, AR
Just did.....It's TIGHT. I mean I got allot going on in that area with the floor shifter and all but best I can tell with the bench slid all the way back....it will fit but depending on shifter travel, HIGH range might be an issue.....
My guess is the sticks will need to be bent.....
Tim
Timmy390
Timmy390
Conway, AR
Looking at this pic it appears things will be OK. Shifter is not a full 9 inches back
Tim
Crush
Greenbottom, WV
That pic is f-n and r-h. So it will be tight even with straight shifters. I am either going to modify the mounting of the twins base or cut and weld the shifters. Havent decided yet
Crush
Greenbottom, WV
ThAt pic is exactly where mine are mounted. It was right at 9” back. You should be good even if you need to bend them forward a bit. Mine have been like that for 6 years. And i keep sayin im gonna change it but i realize that im gonna have to gut the interior again. So i talk myself out of it. Lol
Crush
Greenbottom, WV
Another option is advance or jb fab makes a cable shifter and you can put them where er u want. Lol
Timmy390
Timmy390
Conway, AR
That seems like more worms in the can....LOL
So bottom like is, I think the JB's (J shift) will fit but might need some bending. Good thing I have a shop press :)
I did notice on the JB site, the T and J shift "N" position is different. The T shiters are pointed back at an angle when in "N" but the J shift is straight up.
Tim
bronkenn
Bronco Guy
Southeast Ohio
I bent my JBFab twin stick to fit original hole. First pic is where they came through the floor and the second pic shows where the M5 shifter is compared to the twin sticks on finished floor.
Timmy390
Timmy390
Conway, AR
Didn't realize the 5 speed was that much longer
Yup it's long.....29.5 inches as I recall....
2 different shifter locations.....later ones (like the one I have) has the shifter about 2 inches further back (might be closer to 3). It appears from the location Bronkenn has the later version.
Tim
bronkenn
Bronco Guy
Southeast Ohio
Tim
If I recall correctly there are 3 different shifter locations on the M5. I replaced the shifter cover on mine with a 99 two wheel drive shifter cover to move it back. Barely hits the channel under the floor.
Timmy390
Timmy390
Conway, AR
Mine is a 2000 4x4
Tim
