Two headlight OEM grille?
gmduncan
Annapolis
Did any EB come from the factory with two headlights in their grille?
gmduncan
gmduncan
Annapolis
That's what I thought, but someone is telling me the grill is off an EB. It has the same bolt holes and it's the same dimensions as the OEM grille. Thank you...
Wrightracing
Not a factory option. My front Grille will be wider than stock and I am using Peterbuilt headlights on mine. These two pictures are from a couple friends of mine built it several years ago.
Sent from my SM-N960U using Tapatalk
That is an early Bronco grill, that part is correct.
The quad headlights, that part of the grill is not factory. 100% guarantee that is a custom fabrication.
The people on this site know early Broncos. We know them well. Which headlight switch knob style was used on which year, stuff like that. Tiny little details that most people will never notice. Something as huge as an extra set of headlights, we would know about that. As much as you may not notice the fabrication work done we see it.
So just to be clear, that is a modified factory grill for the extra headlights. Nothing more, nothing less.
gmduncan
gmduncan
Annapolis
Thank you. It was sitting with other parts in a barn and I happened to come across them. Much appreciated.
spap
If you look behind the grill I bet the turn signal attaching pints are behind the second headlight. And interestingly the screw hole to add the second headlights are directly in parts of the grill to attach it
That wright racing truck is bada$$
gmduncan
gmduncan
Annapolis
Yes, all early Broncos came with two headlights! :)
Mark
Now that I took the time to reread what I posted, of course all EB came with two headlights. Damn, I'm an idiot! :)
Did they come with four...? %)
I already know the answer. :-[
As they said, not factory. But it was a somewhat popular modification for adding auxiliary lights to a cramped front end. Larger lights were desirable, but did not fit well on standard grille guards, were too tall for roof mounting, and other options were just few and too far in-between.
So a few clever fabbers would add them to the grille:
This is a '72 model, taken in '76 where the previous owner had added some big driving lights.
The "optional" screen was a BBQ grille we'd found on the trail and put to good use over several camping days.
In your case gmduncan, maybe this one was made for a very early race Bronco. Maybe even a Stroppe prepared one.
I tend to think the lights would have been replaced with more powerful driving lights if that was the case though, but whoever did it really did a nice job of integrating the headlight buckets from another grille into this one. Very nice indeed.
Maybe wanted more light output (notice they're just old standard, as in "dim" headlights), or as many did, were just pining for the old days of 4-headlight grilles like they had on all of their old cars. And maybe really liked the few quad-lamp trucks that had come along over the years.
4WHLFUN
My guess is someone cut the lights out of a donor grill, flipped them and grafted them into another grill. The grill bars tie in very nicely between the lights. This was intentional. Great work!
gmduncan
gmduncan
Annapolis
And here I thought I found a white unicorn! Yes, a second set of OEM lights and buckets were fabbed into the grille. I'll put it on the shelf for a later day.
Thank you all for helping sort this out.
Well, it might not be a unicorn exactly, but it's a pretty rare score anyway I say. Assuming you like that kind of thing, it's a very cool deal. Someone went to a lot of trouble to get that. Replace the old stuff with some modern high-tech lights and you've got quite an array there.
Could be fun. Even as a bit of garage art, it's got some chops.
gmduncan
gmduncan
Annapolis
At first, I was like, What the heck am I going to do with this old Ford grille? But the guy had no need for it and his wife wanted it out of the barn so I took it. Once I found out it's for an EB, I thought it's pretty cool.
El Kabong
Driving stuff Henry built
Yeah, it does look like it was made from 2 grills & done well. Pretty cool even if not stock.
Fwiw, back then most stock vehicles with 2 round headlights used 7" lamps that were combo high/low beam. Most 4 headlight vehicles used four 5 ¾" lamps, 2 that were high/low combos & 2 that were high beam only. :cry:
jckkys
Is there any clue what the fabricator planned to do for front turn signals?
Now that we have LED headlights that are far brighter and LED light bars, the quad headlights are just a way to make an EB ugly. They remind me of the 1979 LTD Country Squire in the Vacation movies, that had 8 headlights, and looked even uglier.
gmduncan
gmduncan
Annapolis
Unfortunately I'm not able to know what he planned to do with four headlights. The original owner/fabricator passed away. He supposedly made a half cab hardtop.
There's got to be a way to install four LED headlights. Make the first set for lo beam and the second set hi beam.
A project for someone else... :)
U13FL735
Here's my handiwork (?) I did this back around 1972...Thought I was going to build some kind of a hot rod out of my 66....
