My horn is going off when I turn the steering wheel sometimes. I spent some time today trying to figure out the problem. I discovered that it only goes off when I push on the top of the wheel. My horn button in the center of the wheel works fine.
My turn signal, hazards, harness is new. I am running a Grant wheel. The adapter has a copper disk on the back that contacts the spring loaded horn contact.
I noticed my new harness has two contacts, one at the top and one at the bottom. The lower one sounds the horn when I ground it. I think my problem is with the one on the top. I put a piece of electric tape under it to see if it was grounding out but the problem only got worse.
What is the top secondary contact for? It is spring loaded just like the loser one. One has a blue wire with a yellow stripe and I think the top one has a blue wire with a black stripe.
Can I just remove the top contact?
The horn should work fine with just the lower contact.
