Uhaul Car trailer
Hawkdoc
Huntsville
Any problems with 32's fitting on a Uhaul car dolly? Talking about the front tire straps they use. I have additional cargo straps but am wondering if the 'standard" straps that come on the trailer will fit the front tires. need to tow north this week and just checking to see if they will fit. Ok, the origianal title said dolly but I am using one of the full trailers to save wear and tear on the rear end on a 11 hour drive. Maybe its time for a beer tonight.
Thanks in advance
Hawkdoc
ShortBus
I've used the uhaul dolly with 33's but I had to deflate them in order to get them to fit. Hope this helps.. Don't forget to have the transfer case in neutral if your drive shafts are in place.
HPaddict
So Cal
I have 32 on my rig. we also had to deflate to get on and off the car dolly. strapping was a bitch too!!!
ShortBus
True- I had to use some ratcheting tie down straps to assist. Total pain but I got it to work too.
Hawkdoc
Hawkdoc
Huntsville
Thanks for the heads up on deflating the tires some. By the way, why are you guys puting the Tcase in neutral? I plan on using some keepers in the back in addtion to the front ones so it shouldn't be rocking back and forth.
Hawkdoc
bigmuddy
Marthasville Missouri
I have used them with a rig up to 35" tires but I had to deflate the tires completely and then I ran the straps over the axles and behind the tires. At first I needed to stop and retighten then it stayed really tight after that. Careful of the brake lines if you do it this way.
Ben
ShortBus
I don't really know the mechanics of it, but everyone will tell you to remove the rear drive shaft if you are using a dolly. At a minimum- you should have the TC in neutral. I don't know what keepers are.
Hawkdoc
Hawkdoc
Huntsville
I am going to use some axle wraps and tie down chains in the back. Sorry about the confusion earlier.
Hawkdoc
Bronco73
Cape Coral, FL
Not sure on the EB case but most any manual tranny that I've heard of can be towed in neutral as long as the t-case and front hubs are not locked in. If the t-case is locked in 4? then the rear wheels turn then causing the front shaft to spin as well. Not a good thing. Any automatic trans needs to have the engine running to get the trans fluid moving through out the trans. If not it will burn the trans bushing up in the rear of the trans if the rear drive shaft is in.
BigO
Ok, the original title said dolly but I am using one of the full trailers to save wear and tear on the rear end on a 11 hour drive.
For my move from Seattle to Savannah (3000 miles!), I used a Budget Rental car trailer instead of a dolly. The straps were plenty long enough for my 31"x10.50" tires, so I am guessing they would work fine for 32" tires too.
dieselracer
Citrus Heights, CA
If you are towing the Bronco on a car dolly backwards then you just need to have the front hubs unlocked. I would suggest locking the steering wheel straight somehow though, you can use ratchet straps to the cage or something.
69 Fl. Bronc
Towed mine on A u-haul trailer from az to fl. 31 tires. A little tight but if you let a little air out, should be no prob.
Ol' Blue 76
Pittsburgh
I've towed mine on both a Uhaul trailer and a budget trailer. I have 31s and both worked fine, the Uhaul had plenty of extra strap length, the budget didn't--but may have just been that individual trailer. Think you should be good to go--good luck!
Chief Master Sergeant
Retired U.S. Air Force
I just hauled mine from Montana to Alaska on a U-Haul trailer in September and I had a hell of a time strapping the front tires down. I run 31 inch tires. The main problem I had with the trailer was the fact the bronco had to ride on the front part of the trailer, which shifted all the weight to the rear tongue. Does that make sense? I would rather have had the weight distributed equally across the trailer.
Viperwolf1
electron whisperer
Please remove the rear driveshaft. With the t-case in neutral and the rear tires spinning the only part of the t-case that will spin is the rear output section which is well above the oil fill line. It normally gets splash lubed from other gears when the input is spinning.
oleguy74
calif city ca
when you tow ,even with t-case in neautral the rear bearing in t-case gets no or little oil(lube)just not recomended.disc drive shaft.not that big of a deal.
broncotime
Grapevine, Texas
I've used the u-haul trailers several times and you are right about the weight being too much forward. I always use my own tie down straps and leave it at least a foot short of the end of the ramps. That still leaves plenty of forward weight so it tows nice, but relieves some of the weight off the hitch. I've used the dolly's before and I hate them. I can back a regular trailer into just about any tight spot, but can't back up the car dolly's if my life depended on it. I actually got stuck in a narrow culdesac one time and had to disconnect the stupid thing! No more dolly's for me.
needabronco
Prescott/Farmington
This is starting to sound like 2 different threads here:
1 Car Dolly; I know this is not your current choice, but if you do put the t-case it neutral, and remove the rear driveshaft. If you do not remove the driveshaft there is no way for the output bearing in the t-case to get lubed and you'll evenutally burn it up.
2 U haul trailer; I've used on with 31's and it went fine. A word of advice don't tell the rental shop that the tires are larger than stock. I had one dealer tell me that they would not rent to me because the 'oversized' was a liability.
Oh yeah, and a word to the wise. Find your own spare and carry it. U-Haul no longer provides a spare because of liability. You have to call and have someone come out and fix or replace the flat. What a pain in the ass. I was on the Alaskan Highway and had to wait over six hours. I'm sure you won't have to wait like that, but...
