Underbody and frame treatment question
Trappey74
Cleveland
My 74 has some typical surface rust on the frame and bottom of the body. No rust through the body anywhere. This rig is in very good shape to have never had any type restoration work done to it. This my first bronco and I feel like one of the first few things I need to do is preserve the quality of the bronco. What are some different cleaning options (pressure wash/light sanding?) as far as getting the frame/under body rust cleaned up and what to coat with?
suckerpunched
If you are not going to pull the body from the frame and just clean up and treat what you can get to. I would use POR15.
jmangi62
I used Rust Bullet black on my frame and under the body and then topcoated it with black automotive enamel.The reason I chose Rust Bullet over POR is because RB is NOT UV sensitive.You can leave the RB or paint over it,you're choice.It dries rock hard too,my frame will last a lifetime now "knock on wood" LOL.:cool:
suckerpunched
Yeah I have used both, they are both great products, I forgot rust bullet came in black. I used silver on something that was silver. used it with no topcoat as well. It is holding up great.
Galt72
I used Rust Bullet silver on mine. That stuff is hard as a rock and covers great. A unexpected bonus is how bright and easy to see everything under the bronco with the silver.
prouddadofthree
Piney Flats, TN
What about pros and cons of media blast vs Chem dip? I've seen so many varying opinions on it I don't know which way to go. I just picked up a 66 but based on Trappey's description it's in a lot worse shape than his. Mines a rust bucket....
dave67fd
This is only assuming your doing a complete frame off as you wouldn't/shouldn't do it otherwise.
Can't say I have heard any varying opinions on chem dip. Havent seen or heard anybody use it. Media blast it like everyone else does.
T
Trappey74
Cleveland
Thanks for advice. looks like I need to put it on a lift and put in some elbow grease. Should I pressure wash and paint everything I canget my hands on underneath? Like arms and everything around the frame?
Steve83
Paint without proper prep will flake & hold water/dirt/salt against the steel, causing it to rust faster. Rubberized undercoating won't flake, unless you spray it over a thick layer of dirt or rust. If you want it painted right, pull the body off the frame and clean everything properly.
This is that same truck after ~10 years of daily driving & weekly wheeling:
But undercoat works.
Toyaddict71
This spring I power washed, scrubbed, wire brushed, and sanded 40+ years of dirt and surface rust off my '74. It took many weekends of the dirtiest work I've ever done on a vehicle to get her clean. I then treated all rust with POR15 and finally sprayed undercoating on it. Anywhere the spray was too messy ( around headers/tranny) I rolled it on. It looks great and I hope will last for many years. Nasty job, but really nice when it's done!
