Undercoating Importance?
NSG
What do you guys/gals think? Is it absolutely necessary to prevent rust?
englewoodcowboy
Lick Creek Restorations
It is a very good idea if you plan on using your EB. Most on here use a spray in bed liner type product you can do yourself or go have it done. It will help quiet things down a bit as well.
bearskinner
N.Idaho, AK, SoCal
its a lot of work, but when I did my body lift I got a heavy wire wheel on a grinder, and stripped all the crud off the underside. I put some 2x4 blocks between the frame and body. I got a quart of rustoleum primer, and a quart of paint and covered the whole underside ( did the frame in black also) It would be nice to do a rotisserie restoration, but this is a great clean up, and you can clearly see the underside.
bearskinner
N.Idaho, AK, SoCal
painted underside to keep an eye on any rust.
ccbronco
I did mine while on a rotisserie. Turned out beautiful. I used a Wurth product.
75junebug
NW Houston Tx
I use an industrial material called Selig Linebacker or CRC SP400. It goes on like liner, but it does not require a heavey coat to protect. It "self heals" itself if it is cut. easy to clean off if needed, all it takes is a cleaner such as varsol,or diesel. clear brown color after it "dries". Its an O2 and H20 barrier, so any rust it is applied to will not continue to rust(within reason, of course)
WheelHorse
I'll second the SP400. Here in the rust belt, I did a personal rust test of fluid film vs the CRC SP400 aka heavy duty corrosion inhibitor.
The SP400 blew the daylights out of the fluid film. While it may not be pretty, it certainly holds true to the 4000hr salt spray test it had passed.
mini73
I am planning on doing the same thing when I do my lift. Going to be a messy job but I figured I could do a little every know and then and eventually it will look better. Would love to do it with the body off but I want to drive my bronco and enjoy it now.
357Bronco
New Hampsha
Fluid Film doesn't cure, and is not designed to be a permanent coating. Read the directions, the product is to be re applied yearly, if not twice a year. It can be removed with a pressure washer if need be.
Crawdad
Does anyone have a website for this SP400? I'm interested in reading more about it. Can you paint over it?
Thx!
nick1975bronco
im in canada in the rust belt just north of vt. and every year I spray my vehicles with and oil based undercoating you can get black or amber but its messy when your working on your vehicles. and it stays soft like grease. I found that asphalt under coating and rocker guard harden up then if moisture gets between that and metal it eats it up and keeps it trapped. u can get it from parts stores or online
nick1975bronco
crc sp400 is a spray like fluid film or wd40. also I saw on gearz there is a company called magnet paints that sells a product that is a paint for underbody. I used kbs coating on my frame like por15
BluebroncoNC
Asheville, NC
Do you plan on breathing in your Bronco? Cause I'm pretty sure that amount of moisture will start one on the path of rusty powdery death. So yes, undercoat or if you're into show trucks, paint your underbelly.
