Upper radiator hose help
73 bronco 347
I have a 73 bronco with a 5.0 out of a 89 mustang with a serpintine setup. I am also using a ron davis radiator with the upper hose on the radiator is on the drivers side. The thermostat housing points start up. I can not find a upper radiator hose for this set up. Any help would be appreciated. Thank you
pcf_mark
Advance Auto #E70480 fits 68-70 (maybe more) GTO with 6.6/400. You need to trim off some excess on the t-stat end. Also watch it does not get too close to the belt if you are using the Explorer PS pump (mounted up high).
