For all of you with a 4R70W and a US Shift controller.
When I am in the top available gear (either OD or 3rd with OD turned off), my electronic speedo does not work - it either sits at 0 mph or bounces around near 100 mph! Initially, I had both grounds from the trans controller tied together with the TPS module and then to the battery. I spoke to US shift and they told me to ensure ground pin #15 is tied to the tps module (not grounded) and ground pin#16 goes to a ground within 1.5 ft of main EFI ECU ground. I made the changes and still have same problem. To be specific, pin 16 and the EFI (MSD atomic EFI) ECU main ground are on the same BUS bar (with all of my grounds) and the BUS is connected to neg batt post with 8 gauge wire.
To make things more confusing, I assumed the problem was due to a short in the actual controller because when the issue starts, if I move the wires that lead into the controller, the speedo begins to work correctly (but that means I have one hand on the wheel and one hand on the controller). US Shift does not think the problem is due to a short because, they said if it was a short, the problem would happen in every gear (not just top gear).
Anyone else have similar issue?
