Vacuum boost brakes
naneumranch
Going to upgrade to vacuum boost brakes looking at getting the Moab kit from Wildhorse. Question is I have ZF5 transmission with hydraulic reservoir next to master cylinder.
naneumranch
naneumranch
Will I have to modify anything or will it bolt up? Or just won’t work ?
Jebus
Longview, WA
You will have to cut the holes in the booster bracket. It should clear. I think you will have to move that prop valve a bit.
I have a wilwood clutch master cyl, but it is close to where yours is.
*On second thought I think it cleared the bracket, without drilling, and it looks closer to the center of vehicle than yours.
