vacuum booster braking issues
treihesse
I I bought a kit from one of the big 3 vendors and I can't get my brakes to work. I will get a pedal on the street but it is weak. On the trail it's almost not there. I have the disc/disc proportion valve. Got a new Mc from a Lincoln with a bigger bore. They just suck. Should I swap out the proportion valve for a h block? Any ideas. .
I have bleed, bench bleed, etc...
Hey TH, is this just a booster kit, or did you swap to disc brakes at the same time?
The biggest issues with booster installs seem to come from linkage rod adjustments.
Is your pedal height where you like it? Are all the rods tight and not floppy? Most importantly is the rod setting between the booster and master correct for that master?
What exactly is yours doing? Soft pedal? Mushy pedal? Something different?
treihesse
treihesse
I have disc disc. Pedal will go to floor in most instances. I did adjust the push rod to the Mc, I had to cut and bend the bracket so maybe it's not get enough throw. But I don't get a great pedal when it's off and just pure hydraulic. I'm wondering if the proportion valve is not working. Can't find any leaks.. bench bleed the mc again?
Were the same brakes working perfectly before the installation of the booster kit?
I don't think a prop valve can fail and cause a soft pedal unless you can find a leak. It can definitely keep your brakes from working properly, but I can't figure out how one would cause a soft pedal.
It's a classic sign of the rod not touching the back of the piston. How far did you adjust it?
What about bleeding? Are the calipers oriented with the bleeders at the top? I know that's basic, and won't likely have anything to do with it if you already had the brakes working.
Bench-bleeding can't hurt, but I wonder if it's called for. It's certainly an air or a travel issue, so better make sure 100% that the mechanical linkages are correct.
Sorry we didn't have more time to talk today, or that we couldn't come up with a better plan of action, but it is acting pretty strange.
I suppose there could be such a thing as a bad booster, which happens a lot with parts these days it seems, but I don't know what in a booster could fail and cause the pedal to go to the floor without it being a rod issue.
Did you verify the depth of the master cylinder's piston before you installed it? Sounds like you did, since you said you adjusted the rod, but I wanted to double-check anyway.
Good luck.
treihesse
treihesse
Paul,
So I found the main issue being the modification to the bracket. The angle change caused a limited amount of engagement. I put in a straight rod from the pedal to the booster. This cured 90%. However the pedal is physically to low so I think if I extend the rod it will push the pedal up and give more engagement.
