Vacuum gauge reading help
SnwMnkys
Orem, Utah
I just finished an EFI swap on my 351w and am trying to fine tune some things. I pulled a vacuum reading and im getting a fluctuation in the needle of about 14.5 to 16. Its a real slow and steady movement, but no pattern in the movement, meaning it will go from 16 to 15 to 15.5 to 14.5 back to 16. Just completely random. Can this be a vacuum leak? Would a bigger cam cause this?
Ive got an FMS cam with 214/224 duration .472/.496 lift, and 112 lobe separation. Nothing aggressive but bigger than stock.
Oh and my vacuum readings probably appear low, but im at 4500ft above sea level, so 15-16 is about normal for me.
I also was pulling my vacuum reading from the port that my FPR hooks up to, i just disconnected the FPR and connected the gauge. Not sure if I should try to hook up the vacuum gauge to its own port and leave the FPR connected or not.
RV77
Springfield,IL
I would leave the FPR alone and find a small intake port. When you take the fpr line off it will raise the idle anyhow.
broncnaz
Sounds ok. Nothing major thats for sure. It may just be intake pulses or with EFI maybe the computer adjusting idle mixture. The engine is fully warm when you are checking right?
S
SnwMnkys
Orem, Utah
Ya engine is fully warm. I just barely got it running so the computer is still learning what to do im assuming.
76 bronco J
Here is another i used that has some good animations from a vacuum gauge.
http://www.secondchancegarage.com/public/186.cfm
>>>>>>> mine is scenario 3 in the link you provided .... that high performance with a little cam scenario isn't mention in the other link provided by steve83....... I have the older ford 315hp. crate motor with the Y303 aluminum heads & E303 cam....
canrel
Bakersfield Ca.
Try unplugging the IAC ( idle air control ) motor. It will constantly be moving while hooked up. The computer is constantly changing the setting trying to keep a steady idle. It is not much but it may cause the reading to change as you discribed. The engine will continue to run with the IAC unplugged.
