Vacuum gauge vs timing light
gick70
So I was having some warm engine hard starting(flooding),so I started messing with the carb,well I decided to get a vacuum gauge to check things out.What I found,I have great starting,no pinging of any kind,idles good,sounds good,smells good(not rich),by using the vacuum gauge more so then the timing light,I had to retard the timing to get in the optimum zone on the vacuum gauge,what goes???I am going to let this go and drive her!! I do have points yet!!
jckkys
The vacuum gauge is useful for many things. Setting initial timing isn't one of them. You'll get the initial timing too far advanced. This will cause kick back with a warm engine. Unless you have a super strong starter motor, it won't start. Read this article on timing; https://www.fordmuscle.com/archives/2000/03/timing/index.php. Hopefully you have timing light. Use the vacuum gauge for setting the idle mixture on the carburetor.
triracer67
I have both, but, I rely on vacuum gauge for the most part. I advance for most vacuum, retard slightly, for idle set. I do the same for idle mixture. I will make sure timing is close with light, but, the vacuum is my go to.
73azbronco
I was just going to say dwell setting but the points of today are such poor quality i will never go back to points ignition, ever.
Yes, vacuum is the real world output of your motor, takes into account engine condition, etc, timing is what the engine is set to, set timing, then vacuum to best performance, backed off at idle just a touch to prevent runon.
savage
Bronco Nut
Renton
I've used both, to fine tune the engine. I have a vacuum / boost gauge my son gave me that I have hooked up all the time ,and its interesting to see how the vacuum is affected by different loads on the engine.
jckkys
Apparently no one read the article I referenced. So I looked for even one source that advised using a vacuum gauge to set initial timing and could find none. I had never heard of it in over 55 yrs. of engine tuning. I have set the timing by ear with acceptable results. Doing it correctly obviously gave better results. I'm beginning to understand why so many give up on distributors and carburetors choosing EFI instead. Optimal tuning does require work and knowledge. If any are interested in achieving the best timing for a specific engine read the article I referenced and this;http://vb.foureyedpride.com/showthread.php?22229-The-Ultimate-Duraspark-Distributor-Timing-Guide
